1 - 16 of 16 Posts
· Neophyte
I really like the simple shot black in .70. I usually run 15mm straight cuts of it for 3/8 steel. It is perfect for target work, don't know about hunting as I don't hunt but it puts a hurting on cans. :) I find it to be very comparable to precise in the same thickness. Just my $0.02.
· aka CYBORG
IMO, Simple's die-cut premium latex tapers are a great deal - 12 high quality bands for under six bux! :) You'll like it.
https://simple-shot.com/diy/3q1xxxxx/simpleshot-die-cut-slingshot-flatband-strips
Just ordered as per your advice, I ordered the next size up so I could do a little modification if need be. I'll be shooting both 3/8" Steel and 5/8" Marbles.
I have 8 x 12 x .4 which is absolutely perfect for quarters, and 15 x 22 x .7 for 3/8 ... Simple-Shot really has it dialed in.
I use SSPL for a month or so. Over a couple bandset I can say I do like it a lot. Haven't touched Precise since then. I don't really like to switch elastics, but had a chance to try diffeent thicknesses of this.latex and it has a very good elongation and retraction speed. Using shorter cuts than Precise and that also increases acceleration path. Have no problem with band life eihter. I think it is a good improvement overall.
Got it and shot it today using 3/8" steel. Had to shorten it up about 3 inches so the active length could be between 6.5 and 7 inches (No more than 7" and not shorter than 6.5") Must say I was very, very impressed, It really sent 3/8" steel out at a good clip, faster than my tubes that were much harder to pull for sure. I put them on a Mule, but I don't think I'm going to stop there ..... I may put them on a F-16 using a rubber band wrap and also on a Chinese ring sling ;- )
The size I got was 22mm wide x 18mm wide x .7mm thick. I got this size because they come 10" long and I knew I would need to cut it down ... BTW: which side should I cut from to keep the most velocity, on this first trail I cut about 1.5 inches from both sides ?
I put the 22mm x 18mm x .7mm Simple Shot flats on a Chinese ring shooter today. Will try it out later today, I have no idea if a did it right or not ?
Looks good but we will see
These flats are vicious. I shot 5/16" steel and they flew out at warp speed, man alive they were on a tightrope. Thank you Alfred E.M. for the heads up ;- ) -- and Boomslang you will NOT be disappointed !
I then shot 3/8" steel and they were flying very, very fast also, not as lightning bolt fast as the 5/16" steel, but they were definitely moving ---- at 25ish yardage (lasered) you could see the 3/8" steel starting to dive a bit where the 5/16" steel looked like they were still going pretty darn flat.
For the light pulling force I'm amazed at the speed I'm getting.
I'm shooting a bit high as my set up is different, but I'll get the knack of it. My shots today were in the 20-25 yard range. Normally where I have been shooting my ranges are a bit longer as my terrain and how close I could get to my targets are different ----- Probably why my shooting never progressed and I shot like fudge !
I'll be shooting this set up again tomorrow and see how it goes, would sure like to bag a Starling :)
· aka CYBORG
One small clarification wll - I'm using the 15 x 22 x .7 and you say you have the 18 x 22 x .7. No matter, they both make ammo fly faster than scalded cats.
Reactions: wll
Yes, that is true, and I do cut about 2.5ish inches off the length as my active length needs to be 6.5 to 6.75ish for my 32.5ish draw length.
Again thank you for the heads up ;- )
1 - 16 of 16 Posts
