1 - 20 of 27 Posts
i just recently got into sling shots and have purchased a marksman sling shot with a folding arm brace the band it came with broke so i purchased a trumark heavy band i installed it and after about (aprox) 200 rounds of rocks metal ball bearings nuts and so one of the things holding the pouch poped out of the surgical rubber i put it back in about 30 times and am wondering if i should bring it in to the place i bought it from and change it in for a tapered band but i fell in love with the distance im getting with the heavy band it shoots amazingly farr and hits realy hard i was out in my feild to test it and i left a dent in a steal drum so i need advice on wether to pull les hard on it when i pull back full strength it eather slides out or afot the realease it pops tomorow im going to check if it changes if not what should i do ? and apologies in adance for the spelling mistakes thanks
you might want to contact Truemark if I remember correctly they were having problems with a batch of connectors. If I can find the info I will post it.
no no liquid kinda think i shoulda it was hard to get it on and i cant conect trumark should i just take it back to the military store but my dad took a look at it he used to have alot of them and said i pulled it back way to far but i was kinda mad about that since the guy at the store said it should last longer and be able to with stand how far i pulled it back
still lasted alot of those shots though still id like to see ideas others have had
also if any one could give me information on shooting the sling shots ? i found that i hjave no ability to aim it manualy but if i see my target i can normaly point and ittl hit at about 50 feet and i would realy like to get more in depth into sling shots
it sounds like you may be a instinctive shooter, you might want to do some reading in the Shooting Techniques section....as far as your bands what is your draw length? you may be drawing them beyond the correct point. How far were you putting the tubes on the forks since you weren't lubricating them??you may not be putting them on far enough. when you lubricate them use rubbing alcohol and let them set over night at least before shooting.
i have no clue but i was pulling that band back about 3 feet with ease and the box said about an inch so i put it about an inch on also where would i look about these shooting techniques also how would i go about cushoning the bars on the wrist thing becouse the metal likes to dig into my arm and thanks for the help so far
realy makes me feel welcome to a forum
Tryhere for the techniques. As far as cushion- you could use anything really , rubber tubing, cloth and tape, paracord, leather. Check what you have and experiment, when you find something that works- pretty it up .
Thanks Skit I forgot it was shooting tips on this forum...that's what happens when you are bouncing back and forth
Had to look thrice myself. I looked back for the "dave rides bikes" thread and recalled Bill saying the info on the connectors wouldn't be up for long- and it is gone now( at least I couldn't find it) . Best to contact TruMark direct for the real scoop.
forgot to mention the bands came with this sun protector thing you put on then wipe off witch i did and yes the bands ere dried it was put onn as instructed after it was put onto the sling shot
Harp is right, Trumark has had problems with the plastic plugs they got from someone. Here's a link to another forum sponsored by Trumark. Maybe they can help you out. They are really a good company. Link below:
http://talk.slingshots.com/forums/index.php
thanks, Flatband
Discussion Starter · #17 ·
ah its alright i fixed it then the one of the bands ripped open aparently to do with the stoper where the band ataches to the device so im probly gona take it back from where i got it and i now i dont know what im going to do get the same one ? get a diferent one make one or order one in
I have shot over 1000 rounds out of my trumark rr2 band. It has no signs of wear. I bought mine direct from trumark however. And I am also using it on a trumark. Maybe you got an older version of the band?
Discussion Starter · #20 ·
that is it
? the package says trumark heavy pull i was using it on a laser hawk folding sling shot which is going back to the dealer on the fact it came with a dangerous prong thing it snaped 2 bands and i was not impressed looking at new ones now T.T
1 - 20 of 27 Posts
