Just finished, minus the fabric and I bought some foam for the back. Made out of 3/4 plywood. The paint is just paint we had lying around from a couple of older projects, but I suppose it looks pretty good if I want to start a circus act or am feeling patriotic. :)
I did manage to finish it with the foam and fabric but it was too late to take pictures so I thought this might be the best one to show off.
I used 2 peices of 1/2" PVC to hang the fabric and slow the ammo before it hits the foam. I also used a piece of 1/2" PVC as can be seen in the picture to hang the targets. Well I built it and a few shots later and the PVC pretty well blew apart. So I'm going to use paracord and a spring for tension. Should work unless someone has a better idea? The PVC was a definite bad idea.
Grandpa Pete
Nice looking catch box. What are the detentions ? How deep is it? I also have had good luck using 1/4" steel rods.I have also used 1/2" copper pipe which I happened to have laying around the shop. 3/4" plywood is pretty heavy. I don't think you'll be shooting through that.
My catch box does triple duty for slingshots, blowgun and pellet gun.
GP
Been using paracord for some time after blowing everything else apart it last a long time and I like the twang when I hit it head on.
Reactions: lycosa
I've got an idea to keep the paracord tight. I have a pretty decent spring that I'm going to attach to a threaded rod and tie the paracord to the spring and put it through the holes i had the PVC in and tie it nice and tight across the box with some spinner targets on the paracord. I believe that'll work and a dead shot on the paracord will be absorbed by the paracord and the spring. At least it's making sense in my head. :)
GP
I wanted to build it like a tank and I think I accomplished that. I have 2 layers of fabric and 2 - 3" of memory foam behind that. I think that'll be plenty enough to stop most shots and last night it did great with 1/2" marbles I was chucking at it. The dimensions of the catch box are 30" wide and 18" tall. I think I'm going to build it up a bit more. Thinking having the catchbox off the ground maybe 2 feet will make plinking at it a little better. I already put a set of old lawnmower wheels that I had lying in the shed on it so I can wheel it around and keep it out of the weather when I'm not using it. It's a bit on the heavy side moving it around so I might be back in the shed to build a stand for it. Wishing I had some bicycle wheels like some lawnmowers have. That would make it a bit easier to move. Still thinking. :hmm:
Now that is swanky!
Thanks for sharing.
Does it have lights?
Reactions: lycosa
