Very nice glad to see you on sotmToday did a little file work, glued up a black, red, black accent liner and made some skull hole fillers for when the attachment screw holes are filled...
Progress so far:
Real nice Mr. Bill the file work on that scorpion is just lovely.Today did a little file work, glued up a black, red, black accent liner and made some skull hole fillers for when the attachment screw holes are filled...
Progress so far:
Looking great fella! Liking itThis is going to take some explaining.......
When I first started lurking around this forum, I did not build anything cause the slingshots with the very nicely tied on bands intimidated me. Had trouble figuring out how it was done and had trouble doing it neatly later. And the bands to pouch tie was even harder for me. Keep in mind I have old dairy farmer fingers. A lot of dexterity left a long time ago!
The woodworking part was pretty straightforward so this SOTM #3 Open Build is my take on what I should have done right away. If I'd only known then what I know now?????
A little laminating work on the frame with maple and walnut with a nice simple Tee style shape. Wrapped with a simple good quality paracord.
Binding post band retention - which is working way better than I would have thought. And is really easy both to build and to install the bands.
The pouch is tied on with simple cotton string with a single constrictor knot and a single square knot over the top.
Shoots beautifully, holds nice and is accurate. Easy to build and band. And is not the ugliest thing I've ever built.
90 mm x 130 mm x 13 mm thick with 18-12-260 0.5 mm Ignite latex bands and a homemade pouch from an old glove.
Not world class like some of the builds on here but it hits the theme or purpose very nicely.
tx, Ed
Lookin Awesome,your skating pretty close to the wire lolToday did a little file work, glued up a black, red, black accent liner and made some skull hole fillers for when the attachment screw holes are filled...
Progress so far:
Looks Great,just out of curiosity,what is the outside to outside dimensions on the fork tips?This is going to take some explaining.......
tx, Ed
90 mm out to out with 20 mm wide tips.Looks Great,just out of curiosity,what is the outside to outside dimensions on the fork tips?
Both are sweet Michael, but I think the targets you often shoot would freeze up in awe of your first entry!I would like to submit a second frame for your consideration. Cottonwood natural.
Build video from Nov 19:
No explanation needed, you have put together a beautiful, usable slingshot that most of us only wish we could make.
Sent from my SM-A716V using Tapatalk
Nice work bill!Last set of pics before before polishing and finishing tomorrow... hopefully will get a shooting video too.
Shaping, with all liners... one drop of glue on each to hold in place.
Shape looks good... after this, took it apart and then reglued and put in the internal pins
Using abralon pads to keep from gouging... starts at 180 grit and goes to 500
Higher grit brings out the natural shine and luster of ironwood
time to put in the skull hole fillers
First set of polish and then after that final fitting and repolishing after
Tomorrow final fitting, and then polishing... will take pics of the final piece and hopefully some shooting if time permits!
That Ironwood is pretty...Last set of pics before before polishing and finishing tomorrow... hopefully will get a shooting video too.
