Can you show an ideal (approx is enough) Width / Taper / Elongation Ratio-(Active Length) / Thickness / PER ammo?
It looks like the info you are seeking might be at the lower end of his data. He addresses the active length question as follows.
I don't include the actual length of the band in the results for 2 reasons.
1). We all have different draw lengths.
2). The band length could be 10mm or more out because of the natural stretch increase over time.
Besides, we all know when we have pulled the band to or close to maximum stretch.
The following subtitles rank the bands from fastest downward. If you want the fastest in each category then it would be the top band listed in the desired category. If the draw weight is a bit more than you prefer then move down the category list until you find the highest speed with your acceptable draw weight. This method of ranking in categories will help you to easily find the band with the fastest speed for your desired max draw weight.
Categories
Ammo - 6mm - FPS OF 270 AND ABOVE
Ammo - 7mm - FPS OF 250 AND ABOVE
Ammo - 8mm - FPS OF 230 AND ABOVE
Ammo - 9.5mm - FPS OF 200 AND ABOVE
Ammo - 6mm - FPS FOR TOP 6 STRAIGHT BAND CUTS
Ammo - 7mm - FPS FOR TOP 6 STRAIGHT BAND CUTS
Ammo - 8mm - FPS FOR TOP 6 STRAIGHT BAND CUTS
Ammo - 9.5mm - FPS FOR TOP 6 STRAIGHT BAND CUTS
Ammo - 6mm - FPS FOR DRAW WEIGHTS OF 6 AND BELOW
Ammo - 7mm - FPS FOR DRAW WEIGHTS OF 6 AND BELOW
Hope this helps
Categories
Hope this helps
