1 - 20 of 21 Posts
You are currently viewing: Test Results: Sumeike, Precise & SoBong…Part 2 - Precise
I recommend that you view the 3 threads in the following order:
Test Results: Sumeike, Precise & SoBong…Part 1 - Sumeike
Test Results: Sumeike, Precise & SoBong…Part 3 - SoBong
Here are the results for Precise 3rd Generation 0.40 to 0.75.
Column 1 = Band cut with ball bearing ammo size.
Column 2 = Average speed in Feet Per Second (FPS)
Column 3 = Draw Weight in pounds (lbs), exactly as it appears on the digital luggage scales.
Column 4 = Temperature indoors, which was always the same.
I don't include the actual length of the band in the results for 2 reasons.
1). We all have different draw lengths.
2). The band length could be 10mm or more out because of the natural stretch increase over time.
Besides, we all know when we have pulled the band to or close to maximum stretch.
PRECISE 3rd Generation 0.40
STRAIGHT FPS DW lbs TEMP
30mm - 30mm 13.54 20 / 64
Ammo - 6mm 287
Ammo - 7mm 273
Ammo - 8mm 257
Ammo - 9.5mm 221
1 - 1 inch 12.48 20 / 64
Ammo - 6mm 284
Ammo - 7mm 272
Ammo - 8mm 252
Ammo - 9.5mm 205
7/8 - 7/8 inch 10.75 20 / 64
Ammo - 6mm 268
Ammo - 7mm 261
Ammo - 8mm 241
Ammo - 9.5mm 200
3/4 - 3/4 inch 9.95 20 / 64
Ammo - 6mm 263
Ammo - 7mm 245
Ammo - 8mm 228
Ammo - 9.5mm 199
5/8 - 5/8 inch 9.50 20 / 64
Ammo - 6mm 225
Ammo - 7mm 207
Ammo - 8mm 193
Ammo - 9.5mm 187
1/2 - 1/2 inch 9.10 20 / 64
Ammo - 6mm 236
Ammo - 7mm 215
Ammo - 8mm 192
Ammo - 9.5mm 179
3/8 - 3/8 inch 6.52 20 / 64
Ammo - 6mm 203
Ammo - 7mm 200
Ammo - 8mm 187
Ammo - 9.5mm 161
TAPERED - 1/8 inch
1 - 7/8 inch 11.80 20 / 64
Ammo - 6mm 296
Ammo - 7mm 277
Ammo - 8mm 258
Ammo - 9.5mm 221
7/8 - 3/4 inch 10.00 20 / 64
Ammo - 6mm 289
Ammo - 7mm 266
Ammo - 8mm 245
Ammo - 9.5mm 209
3/4 - 5/8 inch 9.65 20 / 64
Ammo - 6mm 266
Ammo - 7mm 248
Ammo - 8mm 224
Ammo - 9.5mm 198
5/8 - 1/2 inch 9.13 20 / 64
Ammo - 6mm 246
Ammo - 7mm 229
Ammo - 8mm 209
Ammo - 9.5mm 191
1/2 - 3/8 inch 7.37 20 / 64
Ammo - 6mm 239
Ammo - 7mm 220
Ammo - 8mm 199
Ammo - 9.5mm 170
TAPERED - 1/4 inch
30mm - 25mm 13.15 20 / 64
Ammo - 6mm 303
Ammo - 7mm 289
Ammo - 8mm 270
Ammo - 9.5mm 234
1 - 3/4 inch 10.70 20 / 64
Ammo - 6mm 299
Ammo - 7mm 280
Ammo - 8mm 257
Ammo - 9.5mm 218
7/8 - 5/8 inch 9.31 20 / 64
Ammo - 6mm 293
Ammo - 7mm 272
Ammo - 8mm 249
Ammo - 9.5mm 206
3/4 - 1/2 inch 8.64 20 / 64
Ammo - 6mm 273
Ammo - 7mm 250
Ammo - 8mm 227
Ammo - 9.5mm 193
5/8 - 3/8 inch 7.50 20 / 64
Ammo - 6mm 256
Ammo - 7mm 233
Ammo - 8mm 210
Ammo - 9.5mm 177
TAPERED - 3/8 inch
30mm - 20mm 12.08 20 / 64
Ammo - 6mm 311
Ammo - 7mm 291
Ammo - 8mm 269
Ammo - 9.5mm 232
1 - 5/8 inch 9.97 20 / 64
Ammo - 6mm 303
Ammo - 7mm 282
Ammo - 8mm 257
Ammo - 9.5mm 219
7/8 - 1/2 inch 8.96 20 / 64
Ammo - 6mm 287
Ammo - 7mm 261
Ammo - 8mm 238
Ammo - 9.5mm 201
3/4 - 3/8 inch 8.25 20 / 64
Ammo - 6mm 270
Ammo - 7mm 248
Ammo - 8mm 224
Ammo - 9.5mm 188
TAPERED - 1/2 inch
1 - 1/2 inch 9.74 20 / 64
Ammo - 6mm 301
Ammo - 7mm 280
Ammo - 8mm 253
Ammo - 9.5mm 216
7/8 - 3/8 inch 9.13 20 / 64
Ammo - 6mm 295
Ammo - 7mm 267
Ammo - 8mm 241
Ammo - 9.5mm 201
PRECISE 3rd Generation 0.45
30mm - 30mm 11.57 20 / 64
Ammo - 6mm 273
Ammo - 7mm 261
Ammo - 8mm 249
Ammo - 9.5mm 219
1 - 1 inch 10.85 20 / 64
Ammo - 6mm 281
Ammo - 7mm 266
Ammo - 8mm 243
Ammo - 9.5mm 204
7/8 - 7/8 inch 10.87 20 / 64
Ammo - 6mm 277
Ammo - 7mm 256
Ammo - 8mm 237
Ammo - 9.5mm 197
3/4 - 3/4 inch 7.55 20 / 64
Ammo - 6mm 257
Ammo - 7mm 236
Ammo - 8mm 212
Ammo - 9.5mm 183
5/8 - 5/8 inch 7.05 20 / 64
Ammo - 6mm 245
Ammo - 7mm 224
Ammo - 8mm 199
Ammo - 9.5mm 181
1/2 - 1/2 inch 6.30 20 / 64
Ammo - 6mm 227
Ammo - 7mm 212
Ammo - 8mm 198
Ammo - 9.5mm 171
3/8 - 3/8 inch 5.49 20 / 64
Ammo - 6mm 210
Ammo - 7mm 196
Ammo - 8mm 180
Ammo - 9.5mm 151
TAPERED - 1/8 inch
1 - 7/8 inch 11.17 20 / 64
Ammo - 6mm 288
Ammo - 7mm 265
Ammo - 8mm 238
Ammo - 9.5mm 199
7/8 - 3/4 inch 11.25 20 / 64
Ammo - 6mm 287
Ammo - 7mm 264
Ammo - 8mm 243
Ammo - 9.5mm 202
3/4 - 5/8 inch 7.21 20 / 64
Ammo - 6mm 261
Ammo - 7mm 240
Ammo - 8mm 214
Ammo - 9.5mm 185
5/8 - 1/2 inch 6.65 20 / 64
Ammo - 6mm 253
Ammo - 7mm 232
Ammo - 8mm 209
Ammo - 9.5mm 178
1/2 - 3/8 inch 6.29 20 / 64
Ammo - 6mm 234
Ammo - 7mm 213
Ammo - 8mm 194
Ammo - 9.5mm 166
TAPERED - 1/4 inch
30mm - 25mm 11.52 20 / 64
Ammo - 6mm 289
Ammo - 7mm 272
Ammo - 8mm 258
Ammo - 9.5mm 226
1 - 3/4 inch 9.70 20 / 64
Ammo - 6mm 292
Ammo - 7mm 272
Ammo - 8mm 252
Ammo - 9.5mm 209
7/8 - 5/8 inch 9.64 20 / 64
Ammo - 6mm 290
Ammo - 7mm 266
Ammo - 8mm 240
Ammo - 9.5mm 204
3/4 - 1/2 inch 9.16 20 / 64
Ammo - 6mm 273
Ammo - 7mm 252
Ammo - 8mm 224
Ammo - 9.5mm 194
5/8 - 3/8 inch 7.32 20 / 64
Ammo - 6mm 252
Ammo - 7mm 228
Ammo - 8mm 204
Ammo - 9.5mm 172
TAPERED - 3/8 inch
30mm - 20mm 11.04 20 / 64
Ammo - 6mm 301
Ammo - 7mm 281
Ammo - 8mm 259
Ammo - 9.5mm 224
1 - 5/8 inch 9.26 20 / 64
Ammo - 6mm 295
Ammo - 7mm 274
Ammo - 8mm 249
Ammo - 9.5mm 211
7/8 - 1/2 inch 9.19 20 / 64
Ammo - 6mm 287
Ammo - 7mm 263
Ammo - 8mm 238
Ammo - 9.5mm 201
3/4 - 3/8 inch 10.38 20 / 64
Ammo - 6mm 280
Ammo - 7mm 254
Ammo - 8mm 233
Ammo - 9.5mm 194
TAPERED - 1/2 inch
1 - 1/2 inch 9.05 20 / 64
Ammo - 6mm 300
Ammo - 7mm 273
Ammo - 8mm 245
Ammo - 9.5mm 207
7/8 - 3/8 inch 8.31 20 / 64
Ammo - 6mm 278
Ammo - 7mm 252
Ammo - 8mm 227
Ammo - 9.5mm 191
PRECISE 3rd Generation 0.50
30mm - 30mm 13.83 20 / 64
Ammo - 6mm 269
Ammo - 7mm 264
Ammo - 8mm 249
Ammo - 9.5mm 229
1 - 1 inch 12.32 20 / 64
Ammo - 6mm 273
Ammo - 7mm 258
Ammo - 8mm 246
Ammo - 9.5mm 216
7/8 - 7/8 inch 11.89 20 / 64
Ammo - 6mm 276
Ammo - 7mm 253
Ammo - 8mm 234
Ammo - 9.5mm 213
3/4 - 3/4 inch 10.50 20 / 64
Ammo - 6mm 273
Ammo - 7mm 248
Ammo - 8mm 227
Ammo - 9.5mm 198
5/8 - 5/8 inch 11.58 20 / 64
Ammo - 6mm 246
Ammo - 7mm 215
Ammo - 8mm 204
Ammo - 9.5mm 191
1/2 - 1/2 inch 9.35 20 / 64
Ammo - 6mm 231
Ammo - 7mm 216
Ammo - 8mm 199
Ammo - 9.5mm 182
3/8 - 3/8 inch 7.64 20 / 64
Ammo - 6mm 207
Ammo - 7mm 189
Ammo - 8mm 182
Ammo - 9.5mm 161
TAPERED - 1/8 inch
1 - 7/8 inch 11.86 20 / 64
Ammo - 6mm 289
Ammo - 7mm 275
Ammo - 8mm 250
Ammo - 9.5mm 219
7/8 - 3/4 inch 10.42 20 / 64
Ammo - 6mm 280
Ammo - 7mm 267
Ammo - 8mm 248
Ammo - 9.5mm 211
3/4 - 5/8 inch 10.77 20 / 64
Ammo - 6mm 273
Ammo - 7mm 255
Ammo - 8mm 238
Ammo - 9.5mm 207
5/8 - 1/2 inch 12.20 20 / 64
Ammo - 6mm 266
Ammo - 7mm 242
Ammo - 8mm 224
Ammo - 9.5mm 198
1/2 - 3/8 inch 8.32 20 / 64
Ammo - 6mm 246
Ammo - 7mm 223
Ammo - 8mm 209
Ammo - 9.5mm 180
TAPERED - 1/4 inch
30mm - 25mm 12.94 20 / 64
Ammo - 6mm 285
Ammo - 7mm 273
Ammo - 8mm 261
Ammo - 9.5mm 236
1 - 3/4 inch 11.00 20 / 64
Ammo - 6mm 297
Ammo - 7mm 281
Ammo - 8mm 263
Ammo - 9.5mm 227
7/8 - 5/8 inch 10.57 20 / 64
Ammo - 6mm 295
Ammo - 7mm 275
Ammo - 8mm 255
Ammo - 9.5mm 217
3/4 - 1/2 inch 11.33 20 / 64
Ammo - 6mm 276
Ammo - 7mm 259
Ammo - 8mm 239
Ammo - 9.5mm 206
5/8 - 3/8 inch 10.17 20 / 64
Ammo - 6mm 260
Ammo - 7mm 243
Ammo - 8mm 220
Ammo - 9.5mm 191
TAPERED - 3/8 inch
30mm - 20mm 12.40 20 / 64
Ammo - 6mm 301
Ammo - 7mm 288
Ammo - 8mm 269
Ammo - 9.5mm 236
1 - 5/8 inch 11.17 20 / 64
Ammo - 6mm 307
Ammo - 7mm 290
Ammo - 8mm 266
Ammo - 9.5mm 228
7/8 - 1/2 inch 11.61 20 / 64
Ammo - 6mm 296
Ammo - 7mm 275
Ammo - 8mm 254
Ammo - 9.5mm 218
3/4 - 3/8 inch 12.76 20 / 64
Ammo - 6mm 289
Ammo - 7mm 262
Ammo - 8mm 239
Ammo - 9.5mm 202
TAPERED - 1/2 inch
1 - 1/2 inch 11.20 20 / 64
Ammo - 6mm 314
Ammo - 7mm 295
Ammo - 8mm 268
Ammo - 9.5mm 227
7/8 - 3/8 inch 10.00 20 / 64
Ammo - 6mm 307
Ammo - 7mm 278
Ammo - 8mm 253
Ammo - 9.5mm 212
PRECISE 3rd Generation 0.55
30mm - 30mm 13.27 20 / 64
Ammo - 6mm 228
Ammo - 7mm 226
Ammo - 8mm 213
Ammo - 9.5mm 199
1 - 1 inch 12.29 20 / 64
Ammo - 6mm 250
Ammo - 7mm 230
Ammo - 8mm 221
Ammo - 9.5mm 218
7/8 - 7/8 inch 11.94 20 / 64
Ammo - 6mm 265
Ammo - 7mm 246
Ammo - 8mm 246
Ammo - 9.5mm 219
3/4 - 3/4 inch 10.65 20 / 64
Ammo - 6mm 262
Ammo - 7mm 253
Ammo - 8mm 206
Ammo - 9.5mm 191
5/8 - 5/8 inch 9.56 20 / 64
Ammo - 6mm 256
Ammo - 7mm 243
Ammo - 8mm 202
Ammo - 9.5mm 184
1/2 - 1/2 inch 8.62 20 / 64
Ammo - 6mm 251
Ammo - 7mm 234
Ammo - 8mm 199
Ammo - 9.5mm 186
3/8 - 3/8 inch 7.10 20 / 64
Ammo - 6mm 227
Ammo - 7mm 201
Ammo - 8mm 174
Ammo - 9.5mm 171
TAPERED - 1/8 inch
1 - 7/8 inch 12.22 20 / 64
Ammo - 6mm 263
Ammo - 7mm 258
Ammo - 8mm 247
Ammo - 9.5mm 220
7/8 - 3/4 inch 11.67 20 / 64
Ammo - 6mm 280
Ammo - 7mm 267
Ammo - 8mm 254
Ammo - 9.5mm 223
3/4 - 5/8 inch 10.00 20 / 64
Ammo - 6mm 279
Ammo - 7mm 264
Ammo - 8mm 243
Ammo - 9.5mm 206
5/8 - 1/2 inch 9.06 20 / 64
Ammo - 6mm 272
Ammo - 7mm 252
Ammo - 8mm 234
Ammo - 9.5mm 196
1/2 - 3/8 inch 8.54 20 / 64
Ammo - 6mm 260
Ammo - 7mm 239
Ammo - 8mm 214
Ammo - 9.5mm 182
TAPERED - 1/4 inch
30mm - 25mm 12.93 20 / 64
Ammo - 6mm 247
Ammo - 7mm 244
Ammo - 8mm 238
Ammo - 9.5mm 221
1 - 3/4 inch 11.25 20 / 64
Ammo - 6mm 264
Ammo - 7mm 257
Ammo - 8mm 244
Ammo - 9.5mm 219
7/8 - 5/8 inch 10.56 20 / 64
Ammo - 6mm 292
Ammo - 7mm 277
Ammo - 8mm 255
Ammo - 9.5mm 221
3/4 - 1/2 inch 9.37 20 / 64
Ammo - 6mm 280
Ammo - 7mm 262
Ammo - 8mm 243
Ammo - 9.5mm 206
5/8 - 3/8 inch 8.31 20 / 64
Ammo - 6mm 275
Ammo - 7mm 252
Ammo - 8mm 230
Ammo - 9.5mm 194
TAPERED - 3/8 inch
30mm - 20mm 11.42 20 / 64
Ammo - 6mm 249
Ammo - 7mm 244
Ammo - 8mm 234
Ammo - 9.5mm 213
1 - 5/8 inch 10.79 20 / 64
Ammo - 6mm 278
Ammo - 7mm 267
Ammo - 8mm 252
Ammo - 9.5mm 221
7/8 - 1/2 inch 9.81 20 / 64
Ammo - 6mm 294
Ammo - 7mm 275
Ammo - 8mm 254
Ammo - 9.5mm 217
3/4 - 3/8 inch 8.83 20 / 64
Ammo - 6mm 297
Ammo - 7mm 270
Ammo - 8mm 245
Ammo - 9.5mm 204
TAPERED - 1/2 inch
1 - 1/2 inch 10.26 20 / 64
Ammo - 6mm 296
Ammo - 7mm 280
Ammo - 8mm 258
Ammo - 9.5mm 223
7/8 - 3/8 inch 9.92 20 / 64
Ammo - 6mm 314
Ammo - 7mm 288
Ammo - 8mm 260
Ammo - 9.5mm 219
PRECISE 3rd Generation 0.60
30mm - 30mm 16.04 20 / 64
Ammo - 6mm 252
Ammo - 7mm 249
Ammo - 8mm 244
Ammo - 9.5mm 230
1 - 1 inch 15.76 20 / 64
Ammo - 6mm 285
Ammo - 7mm 278
Ammo - 8mm 260
Ammo - 9.5mm 230
7/8 - 7/8 inch 13.91 20 / 64
Ammo - 6mm 278
Ammo - 7mm 273
Ammo - 8mm 253
Ammo - 9.5mm 230
3/4 - 3/4 inch 10.86 20 / 64
Ammo - 6mm 259
Ammo - 7mm 251
Ammo - 8mm 237
Ammo - 9.5mm 205
5/8 - 5/8 inch 9.15 20 / 64
Ammo - 6mm 252
Ammo - 7mm 240
Ammo - 8mm 209
Ammo - 9.5mm 186
1/2 - 1/2 inch 7.73 20 / 64
Ammo - 6mm 233
Ammo - 7mm 223
Ammo - 8mm 189
Ammo - 9.5mm 183
3/8 - 3/8 inch 8.07 20 / 64
Ammo - 6mm 204
Ammo - 7mm 193
Ammo - 8mm 188
Ammo - 9.5mm 175
TAPERED - 1/8 inch
1 - 7/8 inch 11.98 20 / 64
Ammo - 6mm 239
Ammo - 7mm 236
Ammo - 8mm 228
Ammo - 9.5mm 204
7/8 - 3/4 inch 11.36 20 / 64
Ammo - 6mm 262
Ammo - 7mm 255
Ammo - 8mm 239
Ammo - 9.5mm 213
3/4 - 5/8 inch 9.88 20 / 64
Ammo - 6mm 263
Ammo - 7mm 253
Ammo - 8mm 231
Ammo - 9.5mm 207
5/8 - 1/2 inch 8.66 20 / 64
Ammo - 6mm 265
Ammo - 7mm 250
Ammo - 8mm 233
Ammo - 9.5mm 199
1/2 - 3/8 inch 7.30 20 / 64
Ammo - 6mm 259
Ammo - 7mm 239
Ammo - 8mm 219
Ammo - 9.5mm 185
TAPERED - 1/4 inch
30mm - 25mm 16.18 20 / 64
Ammo - 6mm 279
Ammo - 7mm 270
Ammo - 8mm 268
Ammo - 9.5mm 245
1 - 3/4 inch 14.08 20 / 64
Ammo - 6mm 304
Ammo - 7mm 292
Ammo - 8mm 276
Ammo - 9.5mm 245
Ammo - 6mm 265
Ammo - 7mm 257
Ammo - 8mm 239
Ammo - 9.5mm 215
3/4 - 1/2 inch 9.22 20 / 64
Ammo - 6mm 279
Ammo - 7mm 263
Ammo - 8mm 243
Ammo - 9.5mm 209
5/8 - 3/8 inch 8.45 20 / 64
Ammo - 6mm 280
Ammo - 7mm 256
Ammo - 8mm 235
Ammo - 9.5mm 198
TAPERED - 3/8 inch
30mm - 20mm 15.11 20 / 64
Ammo - 6mm 304
Ammo - 7mm 294
Ammo - 8mm 280
Ammo - 9.5mm 252
1 - 5/8 inch 10.22 20 / 64
Ammo - 6mm 252
Ammo - 7mm 244
Ammo - 8mm 232
Ammo - 9.5mm 210
7/8 - 1/2 inch 10.17 20 / 64
Ammo - 6mm 284
Ammo - 7mm 270
Ammo - 8mm 251
Ammo - 9.5mm 218
3/4 - 3/8 inch 9.06 20 / 64
Ammo - 6mm 296
Ammo - 7mm 272
Ammo - 8mm 245
Ammo - 9.5mm 205
TAPERED - 1/2 inch
1 - 1/2 inch 10.47 20 / 64
Ammo - 6mm 290
Ammo - 7mm 274
Ammo - 8mm 256
Ammo - 9.5mm 222
7/8 - 3/8 inch 9.61 20 / 64
Ammo - 6mm 300
Ammo - 7mm 281
Ammo - 8mm 257
Ammo - 9.5mm 217
PRECISE 3rd Generation 0.65
30mm - 30mm 15.37 20 / 64
Ammo - 6mm 217
Ammo - 7mm 217
Ammo - 8mm 213
Ammo - 9.5mm 204
1 - 1 inch 14.79 20 / 64
Ammo - 6mm 243
Ammo - 7mm 239
Ammo - 8mm 234
Ammo - 9.5mm 221
7/8 - 7/8 inch 14.96 20 / 64
Ammo - 6mm 261
Ammo - 7mm 256
Ammo - 8mm 247
Ammo - 9.5mm 213
3/4 - 3/4 inch 13.91 20 / 64
Ammo - 6mm 279
Ammo - 7mm 269
Ammo - 8mm 257
Ammo - 9.5mm 223
5/8 - 5/8 inch 12.47 20 / 64
Ammo - 6mm 289
Ammo - 7mm 274
Ammo - 8mm 234
Ammo - 9.5mm 208
1/2 - 1/2 inch 12.25 20 / 64
Ammo - 6mm 287
Ammo - 7mm 267
Ammo - 8mm 240
Ammo - 9.5mm 213
3/8 - 3/8 inch 8.85 20 / 64
Ammo - 6mm 255
Ammo - 7mm 238
Ammo - 8mm 208
Ammo - 9.5mm 182
TAPERED - 1/8 inch
1 - 7/8 inch 15.43 20 / 64
Ammo - 6mm 257
Ammo - 7mm 253
Ammo - 8mm 247
Ammo - 9.5mm 229
7/8 - 3/4 inch 14.60 20 / 64
Ammo - 6mm 279
Ammo - 7mm 270
Ammo - 8mm 257
Ammo - 9.5mm 234
3/4 - 5/8 inch 13.37 20 / 64
Ammo - 6mm 296
Ammo - 7mm 283
Ammo - 8mm 266
Ammo - 9.5mm 233
5/8 - 1/2 inch 12.95 20 / 64
Ammo - 6mm 307
Ammo - 7mm 288
Ammo - 8mm 267
Ammo - 9.5mm 228
1/2 - 3/8 inch 9.09 20 / 64
Ammo - 6mm 280
Ammo - 7mm 261
Ammo - 8mm 232
Ammo - 9.5mm 201
TAPERED - 1/4 inch
30mm - 25mm 15.32 20 / 64
Ammo - 6mm 234
Ammo - 7mm 232
Ammo - 8mm 228
Ammo - 9.5mm 215
1 - 3/4 inch 14.27 20 / 64
Ammo - 6mm 262
Ammo - 7mm 256
Ammo - 8mm 248
Ammo - 9.5mm 219
7/8 - 5/8 inch 13.39 20 / 64
Ammo - 6mm 290
Ammo - 7mm 276
Ammo - 8mm 265
Ammo - 9.5mm 233
3/4 - 1/2 inch 12.61 20 / 64
Ammo - 6mm 309
Ammo - 7mm 292
Ammo - 8mm 270
Ammo - 9.5mm 233
5/8 - 3/8 inch 11.26 20 / 64
Ammo - 6mm 303
Ammo - 7mm 280
Ammo - 8mm 256
Ammo - 9.5mm 219
TAPERED - 3/8 inch
30mm - 20mm 14.40 20 / 64
Ammo - 6mm 252
Ammo - 7mm 248
Ammo - 8mm 248
Ammo - 9.5mm 224
1 - 5/8 inch 14.05 20 / 64
Ammo - 6mm 283
Ammo - 7mm 274
Ammo - 8mm 263
Ammo - 9.5mm 232
7/8 - 1/2 inch 13.79 20 / 64
Ammo - 6mm 309
Ammo - 7mm 294
Ammo - 8mm 276
Ammo - 9.5mm 239
3/4 - 3/8 inch 11.58 20 / 64
Ammo - 6mm 322
Ammo - 7mm 301
Ammo - 8mm 277
Ammo - 9.5mm 233
TAPERED - 1/2 inch
1 - 1/2 inch 13.02 20 / 64
Ammo - 6mm 304
Ammo - 7mm 290
Ammo - 8mm 275
Ammo - 9.5mm 242
7/8 - 3/8 inch 12.81 20 / 64
Ammo - 6mm 321
Ammo - 7mm 280
Ammo - 8mm 274
Ammo - 9.5mm 233
PRECISE 3rd Generation 0.70
30mm - 30mm 14.70 20 / 64
Ammo - 6mm 199
Ammo - 7mm 198
Ammo - 8mm 197
Ammo - 9.5mm 188
1 - 1 inch 16.88 20 / 64
Ammo - 6mm 270
Ammo - 7mm 264
Ammo - 8mm 257
Ammo - 9.5mm 239
7/8 - 7/8 inch 15.97 20 / 64
Ammo - 6mm 288
Ammo - 7mm 278
Ammo - 8mm 269
Ammo - 9.5mm 242
3/4 - 3/4 inch 11.72 20 / 64
Ammo - 6mm 244
Ammo - 7mm 238
Ammo - 8mm 228
Ammo - 9.5mm 198
5/8 - 5/8 inch 10.51 20 / 64
Ammo - 6mm 256
Ammo - 7mm 248
Ammo - 8mm 230
Ammo - 9.5mm 193
1/2 - 1/2 inch 9.56 20 / 64
Ammo - 6mm 265
Ammo - 7mm 252
Ammo - 8mm 225
Ammo - 9.5mm 192
3/8 - 3/8 inch 10.44 20 / 64
Ammo - 6mm 265
Ammo - 7mm 245
Ammo - 8mm 227
Ammo - 9.5mm 196
TAPERED - 1/8 inch
1 - 7/8 inch 12.87 20 / 64
Ammo - 6mm 221
Ammo - 7mm 221
Ammo - 8mm 219
Ammo - 9.5mm 208
7/8 - 3/4 inch 11.96 20 / 64
Ammo - 6mm 238
Ammo - 7mm 234
Ammo - 8mm 231
Ammo - 9.5mm 204
3/4 - 5/8 inch 11.25 20 / 64
Ammo - 6mm 258
Ammo - 7mm 251
Ammo - 8mm 227
Ammo - 9.5mm 203
5/8 - 1/2 inch 10.15 20 / 64
Ammo - 6mm 273
Ammo - 7mm 261
Ammo - 8mm 244
Ammo - 9.5mm 212
1/2 - 3/8 inch 8.62 20 / 64
Ammo - 6mm 280
Ammo - 7mm 259
Ammo - 8mm 239
Ammo - 9.5mm 200
TAPERED - 1/4 inch
30mm - 25mm 14.59 20 / 64
Ammo - 6mm 213
Ammo - 7mm 211
Ammo - 8mm 208
Ammo - 9.5mm 202
1 - 3/4 inch 15.46 20 / 64
Ammo - 6mm 295
Ammo - 7mm 287
Ammo - 8mm 276
Ammo - 9.5mm 251
7/8 - 5/8 inch 11.26 20 / 64
Ammo - 6mm 243
Ammo - 7mm 237
Ammo - 8mm 231
Ammo - 9.5mm 205
3/4 - 1/2 inch 10.70 20 / 64
Ammo - 6mm 267
Ammo - 7mm 258
Ammo - 8mm 228
Ammo - 9.5mm 213
5/8 - 3/8 inch 9.32 20 / 64
Ammo - 6mm 283
Ammo - 7mm 265
Ammo - 8mm 245
Ammo - 9.5mm 209
TAPERED - 3/8 inch 15.98 20 / 64
30mm - 20mm
Ammo - 6mm 272
Ammo - 7mm 266
Ammo - 8mm 260
Ammo - 9.5mm 243
1 - 5/8 inch 11.83 20 / 64
Ammo - 6mm 243
Ammo - 7mm 239
Ammo - 8mm 233
Ammo - 9.5mm 206
7/8 - 1/2 inch 10.80 20 / 64
Ammo - 6mm 262
Ammo - 7mm 255
Ammo - 8mm 224
Ammo - 9.5mm 219
3/4 - 3/8 inch 10.15 20 / 64
Ammo - 6mm 289
Ammo - 7mm 274
Ammo - 8mm 254
Ammo - 9.5mm 218
TAPERED - 1/2 inch
1 - 1/2 inch 11.24 20 / 64
Ammo - 6mm 271
Ammo - 7mm 263
Ammo - 8mm 248
Ammo - 9.5mm 227
7/8 - 3/8 inch 10.78 20 / 64
Ammo - 6mm 300
Ammo - 7mm 283
Ammo - 8mm 264
Ammo - 9.5mm 228
PRECISE 3rd Generation 0.75
30mm - 30mm 13.97 20 / 64
Ammo - 6mm 183
Ammo - 7mm 183
Ammo - 8mm 182
Ammo - 9.5mm 178
1 - 1 inch 13.40 20 / 64
Ammo - 6mm 200
Ammo - 7mm 200
Ammo - 8mm 198
Ammo - 9.5mm 191
7/8 - 7/8 inch 12.59 20 / 64
Ammo - 6mm 216
Ammo - 7mm 215
Ammo - 8mm 211
Ammo - 9.5mm 201
3/4 - 3/4 inch 12.11 20 / 64
Ammo - 6mm 238
Ammo - 7mm 235
Ammo - 8mm 227
Ammo - 9.5mm 195
5/8 - 5/8 inch 11.15 20 / 64
Ammo - 6mm 255
Ammo - 7mm 245
Ammo - 8mm 231
Ammo - 9.5mm 204
1/2 - 1/2 inch 10.22 20 / 64
Ammo - 6mm 252
Ammo - 7mm 244
Ammo - 8mm 221
Ammo - 9.5mm 180
3/8 - 3/8 inch 9.21 20 / 64
Ammo - 6mm 245
Ammo - 7mm 228
Ammo - 8mm 192
Ammo - 9.5mm 178
TAPERED - 1/8 inch
1 - 7/8 inch 13.05 20 / 64
Ammo - 6mm 214
Ammo - 7mm 211
Ammo - 8mm 208
Ammo - 9.5mm 196
7/8 - 3/4 inch 12.31 20 / 64
Ammo - 6mm 232
Ammo - 7mm 228
Ammo - 8mm 223
Ammo - 9.5mm 192
3/4 - 5/8 inch 11.67 20 / 64
Ammo - 6mm 254
Ammo - 7mm 248
Ammo - 8mm 235
Ammo - 9.5mm 197
5/8 - 1/2 inch 10.76 20 / 64
Ammo - 6mm 274
Ammo - 7mm 260
Ammo - 8mm 240
Ammo - 9.5mm 211
1/2 - 3/8 inch 10.15 20 / 64
Ammo - 6mm 273
Ammo - 7mm 250
Ammo - 8mm 232
Ammo - 9.5mm 197
TAPERED - 1/4 inch
30mm - 25mm 13.63 20 / 64
Ammo - 6mm 196
Ammo - 7mm 194
Ammo - 8mm 192
Ammo - 9.5mm 188
1 - 3/4 inch 12.71 20 / 64
Ammo - 6mm 222
Ammo - 7mm 218
Ammo - 8mm 214
Ammo - 9.5mm 204
7/8 - 5/8 inch 10.92 20 / 64
Ammo - 6mm 223
Ammo - 7mm 218
Ammo - 8mm 208
Ammo - 9.5mm 186
3/4 - 1/2 inch 11.47 20 / 64
Ammo - 6mm 277
Ammo - 7mm 263
Ammo - 8mm 248
Ammo - 9.5mm 224
5/8 - 3/8 inch 10.64 20 / 64
Ammo - 6mm 292
Ammo - 7mm 276
Ammo - 8mm 255
Ammo - 9.5mm 218
TAPERED - 3/8 inch
30mm - 20mm 13.10 20 / 64
Ammo - 6mm 216
Ammo - 7mm 212
Ammo - 8mm 207
Ammo - 9.5mm 197
1 - 5/8 inch 12.40 20 / 64
Ammo - 6mm 244
Ammo - 7mm 239
Ammo - 8mm 232
Ammo - 9.5mm 197
7/8 - 1/2 inch 11.77 20 / 64
Ammo - 6mm 270
Ammo - 7mm 260
Ammo - 8mm 248
Ammo - 9.5mm 223
3/4 - 3/8 inch 11.26 20 / 64
Ammo - 6mm 305
Ammo - 7mm 287
Ammo - 8mm 267
Ammo - 9.5mm 228
TAPERED - 1/2 inch
1 - 1/2 inch 12.05 20 / 64
Ammo - 6mm 263
Ammo - 7mm 255
Ammo - 8mm 245
Ammo - 9.5mm 223
7/8 - 3/8 inch 10.29 20 / 64
Ammo - 6mm 278
Ammo - 7mm 265
Ammo - 8mm 250
Ammo - 9.5mm 219
Based on this set of data, I can now create an endless amount of lists.
Now, remember that fun day that I mentioned, where I just want to smash cans with a heavy setup and I don't care about band life.
Well, I can use these band results just as they are, or even reduce their active length a tiny bit more for even more power.
The following 4 lists give me an IDEA of the power potential offered by the 4 different sized ball bearings.
Ammo - 6mm - FPS OF 290 AND ABOVE
FPS Band Cut DW Thickness
322 3/4 - 3/8 11.58 0.65
321 7/8 - 3/8 12.81 0.65
314 7/8 - 3/8 9.92 0.55
314 1 - 1/2 11.20 0.50
311 30 - 20 12.08 0.40
309 7/8 - 1/2 13.79 0.65
309 3/4 - 1/2 12.61 0.65
307 5/8 - 1/2 12.95 0.65
307 1 - 5/8 11.17 0.50
307 7/8 - 3/8 10.00 0.50
305 3/4 - 3/8 11.26 0.75
304 30 - 20 15.11 0.60
304 1 - 3/4 14.08 0.60
304 1 - 1/2 13.02 0.65
303 5/8 - 3/8 11.26 0.65
303 30 - 25 13.15 0.40
303 1 - 5/8 9.97 0.40
301 30 - 20 12.40 0.50
301 1 - 1/2 9.74 0.40
301 30 - 20 11.04 0.45
300 7/8 - 3/8 10.78 0.70
300 7/8 - 3/8 9.61 0.60
300 1 - 1/2 9.05 0.45
299 1 - 3/4 10.70 0.40
297 1 - 3/4 11.00 0.50
297 3/4 - 3/8 8.83 0.55
296 7/8 - 1/2 11.61 0.50
296 3/4 - 5/8 13.37 0.65
296 3/4 - 3/8 9.06 0.60
296 1 - 1/2 10.26 0.55
296 1 - 7/8 11.80 0.40
295 7/8 - 3/8 9.13 0.40
295 7/8 - 5/8 10.57 0.50
295 1 - 3/4 15.46 0.70
295 1 - 5/8 9.26 0.45
294 7/8 - 1/2 9.81 0.55
293 7/8 - 5/8 9.31 0.40
292 5/8 - 3/8 10.64 0.75
292 7/8 - 5/8 10.56 0.55
292 1 - 3/4 9.70 0.45
290 7/8 - 5/8 9.64 0.45
290 1 - 1/2 10.47 0.60
290 7/8 - 5/8 13.39 0.65
Ammo - 7mm - FPS OF 280 AND ABOVE
301 3/4 - 3/8 11.58 0.65
295 1 - 1/2 11.20 0.50
294 30 - 20 15.11 0.60
294 7/8 - 1/2 13.79 0.65
292 1 - 3/4 14.08 0.60
292 3/4 - 1/2 12.61 0.65
291 30 - 20 12.08 0.40
290 1 - 5/8 11.17 0.50
290 1 - 1/2 13.02 0.65
289 30 - 25 13.15 0.40
288 5/8 - 1/2 12.95 0.65
288 7/8 - 3/8 9.92 0.55
288 30 - 20 12.40 0.50
287 1 - 3/4 15.46 0.70
287 3/4 - 3/8 11.26 0.75
283 7/8 - 3/8 10.78 0.70
283 3/4 - 5/8 13.37 0.65
282 1 - 5/8 9.97 0.40
281 7/8 - 3/8 9.61 0.60
281 30 - 20 11.04 0.45
281 1 - 3/4 11.00 0.50
280 1 - 3/4 10.70 0.40
280 1 - 1/2 9.74 0.40
280 1 - 1/2 10.26 0.55
280 5/8 - 3/8 11.26 0.65
280 7/8 - 3/8 12.81 0.65
Ammo - 8mm - FPS OF 260 AND ABOVE
280 30 - 20 15.11 0.60
277 3/4 - 3/8 11.58 0.65
276 1 - 3/4 15.46 0.70
276 1 - 3/4 14.08 0.60
276 7/8 - 1/2 13.79 0.65
275 1 - 1/2 13.02 0.65
274 7/8 - 3/8 12.81 0.65
270 30 - 25 13.15 0.40
270 3/4 - 1/2 12.61 0.65
269 7/8 - 7/8 15.97 0.70
269 30 - 20 12.40 0.50
269 30 - 20 12.08 0.40
268 30 - 25 16.18 0.60
268 1 - 1/2 11.20 0.50
267 3/4 - 3/8 11.26 0.75
267 5/8 - 1/2 12.95 0.65
266 1 - 5/8 11.17 0.50
266 3/4 - 5/8 13.37 0.65
265 7/8 - 5/8 13.39 0.65
264 7/8 - 3/8 10.78 0.70
263 1 - 3/4 11.00 0.50
263 1 - 5/8 14.05 0.65
261 30 - 25 12.94 0.50
260 7/8 - 3/8 9.92 0.55
260 1 - 1 15.76 0.60
260 30 - 20 15.98 0.70
Ammo - 9.5mm - FPS OF 220 AND ABOVE
252 30 - 20 15.11 0.60
251 1 - 3/4 15.46 0.70
245 1 - 3/4 14.08 0.60
245 30 - 25 16.18 0.60
243 30 - 20 15.98 0.70
242 7/8 - 7/8 15.97 0.70
242 1 - 1/2 13.02 0.65
239 1 - 1 16.88 0.70
239 7/8 - 1/2 13.79 0.65
236 30 - 20 12.40 0.50
236 30 - 25 12.94 0.50
234 7/8 - 3/4 14.60 0.65
234 30 - 25 13.15 0.40
233 3/4 - 3/8 11.58 0.65
233 7/8 - 3/8 12.81 0.65
233 7/8 - 5/8 13.39 0.65
233 3/4 - 1/2 12.61 0.65
233 3/4 - 5/8 13.37 0.65
232 30 - 20 12.08 0.40
232 1 - 5/8 14.05 0.65
230 30 - 30 16.04 0.60
230 1 - 1 15.76 0.60
230 7/8 - 7/8 13.91 0.60
229 30 - 30 13.83 0.50
229 1 - 7/8 15.43 0.65
228 5/8 - 1/2 12.95 0.65
228 7/8 - 3/8 10.78 0.70
228 3/4 - 3/8 11.26 0.75
228 1 - 5/8 11.17 0.50
227 1 - 3/4 11.00 0.50
227 1 - 1/2 11.24 0.70
227 1 - 1/2 11.20 0.50
226 30 - 25 11.52 0.45
224 30 - 20 11.04 0.45
224 3/4 - 1/2 11.47 0.75
224 30 - 20 14.40 0.65
223 1 - 1/2 10.26 0.55
223 3/4 - 3/4 13.91 0.65
223 1 - 1/2 12.05 0.75
223 7/8 - 1/2 11.77 0.75
223 7/8 - 3/4 11.67 0.55
222 1 - 1/2 10.47 0.60
221 30 - 30 13.54 0.40
221 1 - 7/8 11.80 0.40
221 30 - 25 12.93 0.55
221 1 - 5/8 10.79 0.55
221 7/8 - 5/8 10.56 0.55
221 1 - 1 14.79 0.65
220 1 - 7/8 12.22 0.55
Now, if I want to do the same again, but this time I only want to focus on straight band cuts for some reason,
then the following 4 lists give me an IDEA of the power potential offered by the 4 different sized ball bearings.
Ammo - 6mm - FPS FOR TOP 6 STRAIGHT BAND CUTS
289 5/8 - 5/8 12.47 0.65
288 7/8 - 7/8 15.97 0.70
287 1/2 - 1/2 12.25 0.65
287 30 - 30 13.54 0.40
285 1 - 1 15.76 0.60
284 1 - 1 12.48 0.40
Ammo - 7mm - FPS FOR TOP 6 STRAIGHT BAND CUTS
278 1 - 1 15.76 0.60
278 7/8 - 7/8 15.97 0.70
274 5/8 - 5/8 12.47 0.65
273 30 - 30 13.54 0.40
273 1 - 1 12.48 0.40
273 7/8 - 7/8 13.91 0.60
Ammo - 8mm - FPS FOR TOP 6 STRAIGHT BAND CUTS
257 30 - 30 13.54 0.40
257 3/4 - 3/4 13.91 0.65
257 1 - 1 16.88 0.70
253 7/8 - 7/8 13.91 0.60
Ammo - 9.5mm - FPS FOR TOP 6 STRAIGHT BAND CUTS
Remember when I said that I could also use this set of data to search for light setups too?
Well, I can find the lowest draw weight results and then simply increase the active length until I achieve my desired results for a combination of power,
draw weight, ball bearing size, and of course, band life.
We have 2 more lists below just for that very purpose.
Ammo - 6mm - FPS FOR DRAW WEIGHTS OF 7 AND BELOW
253 5/8 - 1/2 6.65 0.45
234 1/2 - 3/8 6.29 0.45
227 1/2 - 1/2 6.30 0.45
203 3/8 - 3/8 6.52 0.40
210 3/8 - 3/8 5.49 0.45
Ammo - 7mm - FPS FOR DRAW WEIGHTS OF 7 AND BELOW
232 5/8 - 1/2 6.65 0.45
213 1/2 - 3/8 6.29 0.45
212 1/2 - 1/2 6.30 0.45
200 3/8 - 3/8 6.52 0.40
196 3/8 - 3/8 5.49 0.45
Once again, you may experience a slight increase in power when compared to my set of data.
Firstly, for all my testing, I used an over sized pouch which was really meant for 10 - 13mm ammo.
This was the only pouch I had which had big enough holes to fit all the different thicknesses of latex band.
All my other pouches had tiny holes. These pouches would have made me give up on the testing project very quickly.
Secondly, I did not cut the 10mm or so excess latex from the pouch end. This enabled me to re-use the latex.
Now, if you are still interested, you can move onto Test Results: Sumeike, Precise & SoBong…Part 3 - SoBong
Hey Guys,
AKA Forgotten - You are very welcome. I thanked you further in Part 3.
Kalevala - Yes, you understand that this is all about ideas.
If people already have this brand of latex, then the set of data can give you an IDEA of how to get the most out of it.
It can also help to give you an IDEA of which thickness you may want to buy and try.
As well as which thickness you may wish to avoid, therefore saving you some money.
By the way Kalevala, I am a big fan of your videos.
Because of this, I reached out to you a little while ago on one of your youtube videos, and you were kind enough to reply.
So I am glad you have shown an interest in the threads and that they have given you some ideas.
Many thanks for typing all the info and data in the 3 posts. Much appreciated! I know that it must have taken a lot of time. Even the small amount that I post takes more time than you would think. I plan to save all your numbers for future reference. I'm always after top performance with a low draw weight. You saved me lots of time!
Hey Northerner,
I have noticed that you have posted some great band testing information yourself.
I really just copied and pasted the numbers on to the thread to save time.
I tried to do the same on Slingshot Community too, but it just came out a big mess of numbers all bunched together.
So I just gave up on that site. I had absolutely no trouble on this site.
You say that you plan to save all my numbers for future reference.
Well, let me save you the trouble...I left you a gift below...just in case the threads mysteriously disappear in the future.
Hey Northerner,
Excellent! Now I can lay some numbers side-by-side on papers and do easier comparisons. I'm a bit of a numbers addict so this stuff is like diamonds to me.
Thank you, SStallion...More and more my primary interests for shooting are draw weight and matching my ammo to bands.
These data sets just removed a bunch of the trial & error for me.
I am still not settled on a particular brand of elastics...Nit wvwn settled on tubes or bands.
I do prefer tubes if I am backpacking. Easier to maintain & switch out.
For me shooting light is the most fun.
Again much appreciated.
AKA Forgotten - You are welcome.
Northerner - Yes, I thought it would be much easier if you had the documents.
Flatband - I hope you can make use of the sets of data.
(Todd?)
MakoPat - Yes, you are right about removing the trial and error.
This set of data can help people save time and money on latex.
It can help guide you in choosing the correct thickness for your own testing.
It can also help guide you in which thickness to stay away from.
IMPORTANT - I just posted a reply to Projectile Pilot in Part 1.
He correctly posted that his results for Sumeike 0.70 were about 30 FPS faster than mine.
I have copied and pasted my reply below for you all to remember:
Yes, that sounds about right.
Remember, my results are for a 30.5 inch draw, so I would expect your 32 inch draw to get faster speeds.
I would also expect someone with a 34 inch draw to get even faster speeds.
That is why someone on this forum gets 300 FPS with 9.5mm ball bearings using full butterfly. (Not Sumeike)
It's because his draw length is longer still.
For a shorter draw, I would expect all the FPS results to move lower together.
For a longer draw, I would expect all the FPS results to move higher together.
And I would also expect the 23 band cut results to remain more or less in the same order too.
I really appreciate your tests, which are far better than what I have seen in the past 2-3 years.
At this time they are the best reference you can find on Summeike/Precise/Sobong at your draw length of 30.5 inches.
I only hope that the results increase linearly with the draw length.
In other words for the same elastic brand/thickness/ammo but with a longer draw length the speed ratios will stay more or less the same.
It would be great if you could repeat the tests for a draw length of 40, 50 and 60 inches (just kidding since that would take you the entire next week).
Hey Guys,
Northerner asked me a great question in Part 1, so I wanted to post the reply in Part 2 and Part 3 aswell, just in case anyone missed it.
He wrote:
Secretstallion....have you compared your freehand shooting to the machine shooting numbers? It would be interesting to see a few examples. I'm curious if the freehand produces a bit higher numbers. A machine release is completely dead. Freehand shooting can produce a bit more power from an active release and/or a frame flip.
Hey Northerner,
Yes, you are correct in suggesting that freehand slingshot FPS numbers may be slightly higher than testing rig FPS numbers.
I found that when I shoot freehand over a chronograph, I subconsciously try to cheat or 'push' the FPS numbers higher.
This may include drawing back a little further, releasing the ball bearing straight away instead of waiting about 2 seconds like I would do
in real life for aiming purposes and flicking my wrist forward upon release.
So the problem with using freehand is that I could not trust my results because there was no consistency.
I could not replicate these little cheats exactly the same every single time, especially when I don't always know that I am doing it.
This is the whole reason I chose to use the testing rig.
So, like I mentioned in the thread, I used the testing rig to solve these problems and guarantee consistency in my results.
I could not cheat by drawing back any further than 30.5 inch.
I could not cheat by flicking my wrist forward.
And I released the ball bearing 2 seconds after loading which is exactly what I do when I shoot freehand.
Which means my testing rig release is not completely dead as you suggest, because that would also have to mean that my freehand shooting
is completely dead too, because it is the exact same 2 second hold before pouch release.
I mentioned in the threads that you should not be surprised if you get higher FPS numbers when compared to those shown in the set of data.
I mentioned I use an oversized 10-13mm testing pouch and I do not cut the excess 10mm or so of latex from the pouch end.
Well, when you throw in those little cheats I mentioned, you can see why you can achieve higher FPS numbers than those shown.
This is why I kept repeating that this is an IDEA of the FPS, etc.
As an example, once I finished all of my testing, I then cut a 3/4 - 3/8 Sumeike 0.45 band set and then attached it onto my freehand slingshot.
But this time, instead of using an oversized testing pouch meant for 10-13mm, I used a small aerodynamic pouch meant for 6-7mm ball bearings.
This time I also removed the 10mm or so excess latex from the pouch end. I then shot a 6mm ball bearing.
My set of data showed 255 FPS. This time, however, 301 FPS appeared on the chronograph, but I was not surprised.
It was a combination of using the correct sized pouch, removing the excess latex, inconsistent draw length, inconsistent pouch release
and subconscious flicking of the wrist to push my numbers higher.
So my testing rig ensures me consistency in results when comparing FPS, band thickness, band cuts, draw weight and ball bearing size.
The set of data gives you an IDEA of what to expect when using my exact set of test criteria.
You can either enjoy the slightly higher FPS that you may achieve when using the appropriate pouch and shooting freehand,
or you can choose to use a combination of band thickness, band cut, draw weight and ball bearing size to achieve your desired results.
The set of data is the starting point, the rest is where the fun starts.
I am glad you asked this great question because it gives me a chance to add this information just in case someone else is wondering the same thing.
I shall post this on the other 2 comment sections because it is such a great question.
Discussion Starter · #14 ·
Hey Pinguinu01,
I posted a reply to Projectile Pilot in Part 1 which included:
Ammo - 6mm 287
Ammo - 7mm 273
Ammo - 8mm 257
Ammo - 9.5mm 221
Ammo - 6mm 284
Ammo - 7mm 272
Ammo - 8mm 252
Ammo - 9.5mm 205
Ammo - 6mm 268
Ammo - 7mm 261
Ammo - 8mm 241
Ammo - 9.5mm 200
Ammo - 6mm 263
Ammo - 7mm 245
Ammo - 8mm 228
Ammo - 9.5mm 199
Ammo - 6mm 225
Ammo - 7mm 207
Ammo - 8mm 193
Ammo - 9.5mm 187
Ammo - 6mm 236
Ammo - 7mm 215
Ammo - 8mm 192
Ammo - 9.5mm 179
Ammo - 6mm 203
Ammo - 7mm 200
Ammo - 8mm 187
Ammo - 9.5mm 161
TAPERED - 1/8 inch
Ammo - 6mm 296
Ammo - 7mm 277
Ammo - 8mm 258
Ammo - 9.5mm 221
Ammo - 6mm 289
Ammo - 7mm 266
Ammo - 8mm 245
Ammo - 9.5mm 209
Ammo - 6mm 266
Ammo - 7mm 248
Ammo - 8mm 224
Ammo - 9.5mm 198
Ammo - 6mm 246
Ammo - 7mm 229
Ammo - 8mm 209
Ammo - 9.5mm 191
Ammo - 6mm 239
Ammo - 7mm 220
Ammo - 8mm 199
Ammo - 9.5mm 170
TAPERED - 1/4 inch
Ammo - 6mm 303
Ammo - 7mm 289
Ammo - 8mm 270
Ammo - 9.5mm 234
Ammo - 6mm 299
Ammo - 7mm 280
Ammo - 8mm 257
Ammo - 9.5mm 218
Ammo - 6mm 293
Ammo - 7mm 272
Ammo - 8mm 249
Ammo - 9.5mm 206
Ammo - 6mm 273
Ammo - 7mm 250
Ammo - 8mm 227
Ammo - 9.5mm 193
Ammo - 6mm 256
Ammo - 7mm 233
Ammo - 8mm 210
Ammo - 9.5mm 177
TAPERED - 3/8 inch
Ammo - 6mm 311
Ammo - 7mm 291
Ammo - 8mm 269
Ammo - 9.5mm 232
Ammo - 6mm 303
Ammo - 7mm 282
Ammo - 8mm 257
Ammo - 9.5mm 219
Ammo - 6mm 287
Ammo - 7mm 261
Ammo - 8mm 238
Ammo - 9.5mm 201
Ammo - 6mm 270
Ammo - 7mm 248
Ammo - 8mm 224
Ammo - 9.5mm 188
TAPERED - 1/2 inch
Ammo - 6mm 301
Ammo - 7mm 280
Ammo - 8mm 253
Ammo - 9.5mm 216
Ammo - 6mm 295
Ammo - 7mm 267
Ammo - 8mm 241
Ammo - 9.5mm 201
Ammo - 6mm 273
Ammo - 7mm 261
Ammo - 8mm 249
Ammo - 9.5mm 219
Ammo - 6mm 281
Ammo - 7mm 266
Ammo - 8mm 243
Ammo - 9.5mm 204
Ammo - 6mm 277
Ammo - 7mm 256
Ammo - 8mm 237
Ammo - 9.5mm 197
Ammo - 6mm 257
Ammo - 7mm 236
Ammo - 8mm 212
Ammo - 9.5mm 183
Ammo - 6mm 245
Ammo - 7mm 224
Ammo - 8mm 199
Ammo - 9.5mm 181
Ammo - 6mm 227
Ammo - 7mm 212
Ammo - 8mm 198
Ammo - 9.5mm 171
Ammo - 6mm 210
Ammo - 7mm 196
Ammo - 8mm 180
Ammo - 9.5mm 151
TAPERED - 1/8 inch
Ammo - 6mm 288
Ammo - 7mm 265
Ammo - 8mm 238
Ammo - 9.5mm 199
Ammo - 6mm 287
Ammo - 7mm 264
Ammo - 8mm 243
Ammo - 9.5mm 202
Ammo - 6mm 261
Ammo - 7mm 240
Ammo - 8mm 214
Ammo - 9.5mm 185
Ammo - 6mm 253
Ammo - 7mm 232
Ammo - 8mm 209
Ammo - 9.5mm 178
Ammo - 6mm 234
Ammo - 7mm 213
Ammo - 8mm 194
Ammo - 9.5mm 166
TAPERED - 1/4 inch
Ammo - 6mm 289
Ammo - 7mm 272
Ammo - 8mm 258
Ammo - 9.5mm 226
Ammo - 6mm 292
Ammo - 7mm 272
Ammo - 8mm 252
Ammo - 9.5mm 209
Ammo - 6mm 290
Ammo - 7mm 266
Ammo - 8mm 240
Ammo - 9.5mm 204
Ammo - 6mm 273
Ammo - 7mm 252
Ammo - 8mm 224
Ammo - 9.5mm 194
Ammo - 6mm 252
Ammo - 7mm 228
Ammo - 8mm 204
Ammo - 9.5mm 172
TAPERED - 3/8 inch
Ammo - 6mm 301
Ammo - 7mm 281
Ammo - 8mm 259
Ammo - 9.5mm 224
Ammo - 6mm 295
Ammo - 7mm 274
Ammo - 8mm 249
Ammo - 9.5mm 211
Ammo - 6mm 287
Ammo - 7mm 263
Ammo - 8mm 238
Ammo - 9.5mm 201
Ammo - 6mm 280
Ammo - 7mm 254
Ammo - 8mm 233
Ammo - 9.5mm 194
TAPERED - 1/2 inch
Ammo - 6mm 300
Ammo - 7mm 273
Ammo - 8mm 245
Ammo - 9.5mm 207
Ammo - 6mm 278
Ammo - 7mm 252
Ammo - 8mm 227
Ammo - 9.5mm 191
Ammo - 6mm 269
Ammo - 7mm 264
Ammo - 8mm 249
Ammo - 9.5mm 229
Ammo - 6mm 273
Ammo - 7mm 258
Ammo - 8mm 246
Ammo - 9.5mm 216
Ammo - 6mm 276
Ammo - 7mm 253
Ammo - 8mm 234
Ammo - 9.5mm 213
Ammo - 6mm 273
Ammo - 7mm 248
Ammo - 8mm 227
Ammo - 9.5mm 198
Ammo - 6mm 246
Ammo - 7mm 215
Ammo - 8mm 204
Ammo - 9.5mm 191
Ammo - 6mm 231
Ammo - 7mm 216
Ammo - 8mm 199
Ammo - 9.5mm 182
Ammo - 6mm 207
Ammo - 7mm 189
Ammo - 8mm 182
Ammo - 9.5mm 161
TAPERED - 1/8 inch
Ammo - 6mm 289
Ammo - 7mm 275
Ammo - 8mm 250
Ammo - 9.5mm 219
Ammo - 6mm 280
Ammo - 7mm 267
Ammo - 8mm 248
Ammo - 9.5mm 211
Ammo - 6mm 273
Ammo - 7mm 255
Ammo - 8mm 238
Ammo - 9.5mm 207
Ammo - 6mm 266
Ammo - 7mm 242
Ammo - 8mm 224
Ammo - 9.5mm 198
Ammo - 6mm 246
Ammo - 7mm 223
Ammo - 8mm 209
Ammo - 9.5mm 180
TAPERED - 1/4 inch
Ammo - 6mm 285
Ammo - 7mm 273
Ammo - 8mm 261
Ammo - 9.5mm 236
Ammo - 6mm 297
Ammo - 7mm 281
Ammo - 8mm 263
Ammo - 9.5mm 227
Ammo - 6mm 295
Ammo - 7mm 275
Ammo - 8mm 255
Ammo - 9.5mm 217
Ammo - 6mm 276
Ammo - 7mm 259
Ammo - 8mm 239
Ammo - 9.5mm 206
Ammo - 6mm 260
Ammo - 7mm 243
Ammo - 8mm 220
Ammo - 9.5mm 191
TAPERED - 3/8 inch
Ammo - 6mm 301
Ammo - 7mm 288
Ammo - 8mm 269
Ammo - 9.5mm 236
Ammo - 6mm 307
Ammo - 7mm 290
Ammo - 8mm 266
Ammo - 9.5mm 228
Ammo - 6mm 296
Ammo - 7mm 275
Ammo - 8mm 254
Ammo - 9.5mm 218
Ammo - 6mm 289
Ammo - 7mm 262
Ammo - 8mm 239
Ammo - 9.5mm 202
TAPERED - 1/2 inch
Ammo - 6mm 314
Ammo - 7mm 295
Ammo - 8mm 268
Ammo - 9.5mm 227
Ammo - 6mm 307
Ammo - 7mm 278
Ammo - 8mm 253
Ammo - 9.5mm 212
Ammo - 6mm 228
Ammo - 7mm 226
Ammo - 8mm 213
Ammo - 9.5mm 199
Ammo - 6mm 250
Ammo - 7mm 230
Ammo - 8mm 221
Ammo - 9.5mm 218
Ammo - 6mm 265
Ammo - 7mm 246
Ammo - 8mm 246
Ammo - 9.5mm 219
Ammo - 6mm 262
Ammo - 7mm 253
Ammo - 8mm 206
Ammo - 9.5mm 191
Ammo - 6mm 256
Ammo - 7mm 243
Ammo - 8mm 202
Ammo - 9.5mm 184
Ammo - 6mm 251
Ammo - 7mm 234
Ammo - 8mm 199
Ammo - 9.5mm 186
Ammo - 6mm 227
Ammo - 7mm 201
Ammo - 8mm 174
Ammo - 9.5mm 171
TAPERED - 1/8 inch
Ammo - 6mm 263
Ammo - 7mm 258
Ammo - 8mm 247
Ammo - 9.5mm 220
Ammo - 6mm 280
Ammo - 7mm 267
Ammo - 8mm 254
Ammo - 9.5mm 223
Ammo - 6mm 279
Ammo - 7mm 264
Ammo - 8mm 243
Ammo - 9.5mm 206
Ammo - 6mm 272
Ammo - 7mm 252
Ammo - 8mm 234
Ammo - 9.5mm 196
Ammo - 6mm 260
Ammo - 7mm 239
Ammo - 8mm 214
Ammo - 9.5mm 182
TAPERED - 1/4 inch
Ammo - 6mm 247
Ammo - 7mm 244
Ammo - 8mm 238
Ammo - 9.5mm 221
Ammo - 6mm 264
Ammo - 7mm 257
Ammo - 8mm 244
Ammo - 9.5mm 219
Ammo - 6mm 292
Ammo - 7mm 277
Ammo - 8mm 255
Ammo - 9.5mm 221
Ammo - 6mm 280
Ammo - 7mm 262
Ammo - 8mm 243
Ammo - 9.5mm 206
Ammo - 6mm 275
Ammo - 7mm 252
Ammo - 8mm 230
Ammo - 9.5mm 194
TAPERED - 3/8 inch
Ammo - 6mm 249
Ammo - 7mm 244
Ammo - 8mm 234
Ammo - 9.5mm 213
Ammo - 6mm 278
Ammo - 7mm 267
Ammo - 8mm 252
Ammo - 9.5mm 221
Ammo - 6mm 294
Ammo - 7mm 275
Ammo - 8mm 254
Ammo - 9.5mm 217
Ammo - 6mm 297
Ammo - 7mm 270
Ammo - 8mm 245
Ammo - 9.5mm 204
TAPERED - 1/2 inch
Ammo - 6mm 296
Ammo - 7mm 280
Ammo - 8mm 258
Ammo - 9.5mm 223
Ammo - 6mm 314
Ammo - 7mm 288
Ammo - 8mm 260
Ammo - 9.5mm 219
Ammo - 6mm 252
Ammo - 7mm 249
Ammo - 8mm 244
Ammo - 9.5mm 230
Ammo - 6mm 285
Ammo - 7mm 278
Ammo - 8mm 260
Ammo - 9.5mm 230
Ammo - 6mm 278
Ammo - 7mm 273
Ammo - 8mm 253
Ammo - 9.5mm 230
Ammo - 6mm 259
Ammo - 7mm 251
Ammo - 8mm 237
Ammo - 9.5mm 205
Ammo - 6mm 252
Ammo - 7mm 240
Ammo - 8mm 209
Ammo - 9.5mm 186
Ammo - 6mm 233
Ammo - 7mm 223
Ammo - 8mm 189
Ammo - 9.5mm 183
Ammo - 6mm 204
Ammo - 7mm 193
Ammo - 8mm 188
Ammo - 9.5mm 175
TAPERED - 1/8 inch
Ammo - 6mm 239
Ammo - 7mm 236
Ammo - 8mm 228
Ammo - 9.5mm 204
Ammo - 6mm 262
Ammo - 7mm 255
Ammo - 8mm 239
Ammo - 9.5mm 213
Ammo - 6mm 263
Ammo - 7mm 253
Ammo - 8mm 231
Ammo - 9.5mm 207
Ammo - 6mm 265
Ammo - 7mm 250
Ammo - 8mm 233
Ammo - 9.5mm 199
Ammo - 6mm 259
Ammo - 7mm 239
Ammo - 8mm 219
Ammo - 9.5mm 185
TAPERED - 1/4 inch
Ammo - 6mm 279
Ammo - 7mm 270
Ammo - 8mm 268
Ammo - 9.5mm 245
Ammo - 6mm 304
Ammo - 7mm 292
Ammo - 8mm 276
Ammo - 9.5mm 245
Ammo - 6mm 265
Ammo - 7mm 257
Ammo - 8mm 239
Ammo - 9.5mm 215
Ammo - 6mm 279
Ammo - 7mm 263
Ammo - 8mm 243
Ammo - 9.5mm 209
Ammo - 6mm 280
Ammo - 7mm 256
Ammo - 8mm 235
Ammo - 9.5mm 198
TAPERED - 3/8 inch
Ammo - 6mm 304
Ammo - 7mm 294
Ammo - 8mm 280
Ammo - 9.5mm 252
Ammo - 6mm 252
Ammo - 7mm 244
Ammo - 8mm 232
Ammo - 9.5mm 210
Ammo - 6mm 284
Ammo - 7mm 270
Ammo - 8mm 251
Ammo - 9.5mm 218
Ammo - 6mm 296
Ammo - 7mm 272
Ammo - 8mm 245
Ammo - 9.5mm 205
TAPERED - 1/2 inch
Ammo - 6mm 290
Ammo - 7mm 274
Ammo - 8mm 256
Ammo - 9.5mm 222
Ammo - 6mm 300
Ammo - 7mm 281
Ammo - 8mm 257
Ammo - 9.5mm 217
Ammo - 6mm 217
Ammo - 7mm 217
Ammo - 8mm 213
Ammo - 9.5mm 204
Ammo - 6mm 243
Ammo - 7mm 239
Ammo - 8mm 234
Ammo - 9.5mm 221
Ammo - 6mm 261
Ammo - 7mm 256
Ammo - 8mm 247
Ammo - 9.5mm 213
Ammo - 6mm 279
Ammo - 7mm 269
Ammo - 8mm 257
Ammo - 9.5mm 223
Ammo - 6mm 289
Ammo - 7mm 274
Ammo - 8mm 234
Ammo - 9.5mm 208
Ammo - 6mm 287
Ammo - 7mm 267
Ammo - 8mm 240
Ammo - 9.5mm 213
Ammo - 6mm 255
Ammo - 7mm 238
Ammo - 8mm 208
Ammo - 9.5mm 182
TAPERED - 1/8 inch
Ammo - 6mm 257
Ammo - 7mm 253
Ammo - 8mm 247
Ammo - 9.5mm 229
Ammo - 6mm 279
Ammo - 7mm 270
Ammo - 8mm 257
Ammo - 9.5mm 234
Ammo - 6mm 296
Ammo - 7mm 283
Ammo - 8mm 266
Ammo - 9.5mm 233
Ammo - 6mm 307
Ammo - 7mm 288
Ammo - 8mm 267
Ammo - 9.5mm 228
Ammo - 6mm 280
Ammo - 7mm 261
Ammo - 8mm 232
Ammo - 9.5mm 201
TAPERED - 1/4 inch
Ammo - 6mm 234
Ammo - 7mm 232
Ammo - 8mm 228
Ammo - 9.5mm 215
Ammo - 6mm 262
Ammo - 7mm 256
Ammo - 8mm 248
Ammo - 9.5mm 219
Ammo - 6mm 290
Ammo - 7mm 276
Ammo - 8mm 265
Ammo - 9.5mm 233
Ammo - 6mm 309
Ammo - 7mm 292
Ammo - 8mm 270
Ammo - 9.5mm 233
Ammo - 6mm 303
Ammo - 7mm 280
Ammo - 8mm 256
Ammo - 9.5mm 219
TAPERED - 3/8 inch
Ammo - 6mm 252
Ammo - 7mm 248
Ammo - 8mm 248
Ammo - 9.5mm 224
Ammo - 6mm 283
Ammo - 7mm 274
Ammo - 8mm 263
Ammo - 9.5mm 232
Ammo - 6mm 309
Ammo - 7mm 294
Ammo - 8mm 276
Ammo - 9.5mm 239
Ammo - 6mm 322
Ammo - 7mm 301
Ammo - 8mm 277
Ammo - 9.5mm 233
TAPERED - 1/2 inch
Ammo - 6mm 304
Ammo - 7mm 290
Ammo - 8mm 275
Ammo - 9.5mm 242
Ammo - 6mm 321
Ammo - 7mm 280
Ammo - 8mm 274
Ammo - 9.5mm 233
Ammo - 6mm 199
Ammo - 7mm 198
Ammo - 8mm 197
Ammo - 9.5mm 188
Ammo - 6mm 270
Ammo - 7mm 264
Ammo - 8mm 257
Ammo - 9.5mm 239
Ammo - 6mm 288
Ammo - 7mm 278
Ammo - 8mm 269
Ammo - 9.5mm 242
Ammo - 6mm 244
Ammo - 7mm 238
Ammo - 8mm 228
Ammo - 9.5mm 198
Ammo - 6mm 256
Ammo - 7mm 248
Ammo - 8mm 230
Ammo - 9.5mm 193
Ammo - 6mm 265
Ammo - 7mm 252
Ammo - 8mm 225
Ammo - 9.5mm 192
Ammo - 6mm 265
Ammo - 7mm 245
Ammo - 8mm 227
Ammo - 9.5mm 196
TAPERED - 1/8 inch
Ammo - 6mm 221
Ammo - 7mm 221
Ammo - 8mm 219
Ammo - 9.5mm 208
Ammo - 6mm 238
Ammo - 7mm 234
Ammo - 8mm 231
Ammo - 9.5mm 204
Ammo - 6mm 258
Ammo - 7mm 251
Ammo - 8mm 227
Ammo - 9.5mm 203
Ammo - 6mm 273
Ammo - 7mm 261
Ammo - 8mm 244
Ammo - 9.5mm 212
Ammo - 6mm 280
Ammo - 7mm 259
Ammo - 8mm 239
Ammo - 9.5mm 200
TAPERED - 1/4 inch
Ammo - 6mm 213
Ammo - 7mm 211
Ammo - 8mm 208
Ammo - 9.5mm 202
Ammo - 6mm 295
Ammo - 7mm 287
Ammo - 8mm 276
Ammo - 9.5mm 251
Ammo - 6mm 243
Ammo - 7mm 237
Ammo - 8mm 231
Ammo - 9.5mm 205
Ammo - 6mm 267
Ammo - 7mm 258
Ammo - 8mm 228
Ammo - 9.5mm 213
Ammo - 6mm 283
Ammo - 7mm 265
Ammo - 8mm 245
Ammo - 9.5mm 209
30mm - 20mm
Ammo - 6mm 272
Ammo - 7mm 266
Ammo - 8mm 260
Ammo - 9.5mm 243
Ammo - 6mm 243
Ammo - 7mm 239
Ammo - 8mm 233
Ammo - 9.5mm 206
Ammo - 6mm 262
Ammo - 7mm 255
Ammo - 8mm 224
Ammo - 9.5mm 219
Ammo - 6mm 289
Ammo - 7mm 274
Ammo - 8mm 254
Ammo - 9.5mm 218
TAPERED - 1/2 inch
Ammo - 6mm 271
Ammo - 7mm 263
Ammo - 8mm 248
Ammo - 9.5mm 227
Ammo - 6mm 300
Ammo - 7mm 283
Ammo - 8mm 264
Ammo - 9.5mm 228
Ammo - 6mm 183
Ammo - 7mm 183
Ammo - 8mm 182
Ammo - 9.5mm 178
Ammo - 6mm 200
Ammo - 7mm 200
Ammo - 8mm 198
Ammo - 9.5mm 191
Ammo - 6mm 216
Ammo - 7mm 215
Ammo - 8mm 211
Ammo - 9.5mm 201
Ammo - 6mm 238
Ammo - 7mm 235
Ammo - 8mm 227
Ammo - 9.5mm 195
Ammo - 6mm 255
Ammo - 7mm 245
Ammo - 8mm 231
Ammo - 9.5mm 204
Ammo - 6mm 252
Ammo - 7mm 244
Ammo - 8mm 221
Ammo - 9.5mm 180
Ammo - 6mm 245
Ammo - 7mm 228
Ammo - 8mm 192
Ammo - 9.5mm 178
TAPERED - 1/8 inch
Ammo - 6mm 214
Ammo - 7mm 211
Ammo - 8mm 208
Ammo - 9.5mm 196
Ammo - 6mm 232
Ammo - 7mm 228
Ammo - 8mm 223
Ammo - 9.5mm 192
Ammo - 6mm 254
Ammo - 7mm 248
Ammo - 8mm 235
Ammo - 9.5mm 197
Ammo - 6mm 274
Ammo - 7mm 260
Ammo - 8mm 240
Ammo - 9.5mm 211
Ammo - 6mm 273
Ammo - 7mm 250
Ammo - 8mm 232
Ammo - 9.5mm 197
TAPERED - 1/4 inch
Ammo - 6mm 196
Ammo - 7mm 194
Ammo - 8mm 192
Ammo - 9.5mm 188
Ammo - 6mm 222
Ammo - 7mm 218
Ammo - 8mm 214
Ammo - 9.5mm 204
Ammo - 6mm 223
Ammo - 7mm 218
Ammo - 8mm 208
Ammo - 9.5mm 186
Ammo - 6mm 277
Ammo - 7mm 263
Ammo - 8mm 248
Ammo - 9.5mm 224
Ammo - 6mm 292
Ammo - 7mm 276
Ammo - 8mm 255
Ammo - 9.5mm 218
TAPERED - 3/8 inch
Ammo - 6mm 216
Ammo - 7mm 212
Ammo - 8mm 207
Ammo - 9.5mm 197
Ammo - 6mm 244
Ammo - 7mm 239
Ammo - 8mm 232
Ammo - 9.5mm 197
Ammo - 6mm 270
Ammo - 7mm 260
Ammo - 8mm 248
Ammo - 9.5mm 223
Ammo - 6mm 305
Ammo - 7mm 287
Ammo - 8mm 267
Ammo - 9.5mm 228
TAPERED - 1/2 inch
Ammo - 6mm 263
Ammo - 7mm 255
Ammo - 8mm 245
Ammo - 9.5mm 223
Ammo - 6mm 278
Ammo - 7mm 265
Ammo - 8mm 250
Ammo - 9.5mm 219
Just what I need -any way to print this out ?
1 - 20 of 21 Posts
