I've recently gotten back into shooting slingshots again and have followed with interest the discussion on Chinese tubes. As a retired physicist, I have time to try to make sense of the unexpected result that tapered bands (e.g., 4 strand mixed with 2 strand on each side) can outperform single bands (e.g. 2 strands per side). One can algebraically model a slingshot in which each side is composed of 2 strands in series, with each strand having different stiffness, mass, length, etc.. In the simplified case where the draw force is proportional to the amount of draw beyond the unpulled length (="draw length"), I did not find any advantage to pseudo tapered bands over untapered at CONSTANT draw length AND pull force; (by untapered, I mean constant band configuration all the way between pouch and slingshot "Y") . This calculation includes the mass of the rubber bands, the variation in velocity along the bands, and the mass of the pouch and projectile.
To get constant draw length and pull force for different types of bands, one needs to change the unstretched length of band(s). It seems that many on this forum are not aware of some general rules that can help understand observations. In particular, the pull force at a given draw can be doubled by doubling the number of identical strands side-by-side (i.e., in parallel) or by HALVING the UNstretched length of all bands. Alternatively, the pull force at a given draw length can be halved by halving the number of bands in parallel or by doubling the UNstretched length of all bands. This means that it is very important to carefully monitor the UNstretched length of bands as this can make more difference in stiffness than the band type (e.g., 2040, 1745, etc.).
I'm not sure why I didn't find it favorable to have pseudo-tapered bands at constant draw length & pull force. It is hard to know what the pull force is, so the various speed measurements that are being reported in this forum are hard to do at constant pull force. Also, if the pull force is reduced by tapering, it becomes easier to pull the pouch back and draw lengths are likely to increase as a result. Projectile speed is pretty sensitive to draw length, so an unplanned extra draw length could be contributing to a perception of higher speed for pseudo-tapered.
For the numerically oriented, the stiffness constants k (which have units of force / "draw length" ) combine in parallel like
k.effective = k1 + k2 (k1 & k2 in parallel),
while in series combine like
1/k.effective = 1/k1 + 1/k2 (k2 added to end of k1 (="series" connection)).
So be sure to report unstretched band lengths, and when possible control draw lengths and measure the force needed to achieve such draw lengths.
