I too was absolutely amazed at the power that those bands generate with 3/8 steel. I use them on all my target frames and make sure beginners start with them too. Good stuff tex makes.
Alot of people really like tubes, myself included.Why does everybody hate tubes so much?
i hate flatsWhy does everybody hate tubes so much?
Edit to above 22mm straight FPS. Last night did some more chrony of the 22mm in Thera and got speeds of 208 to 220 fps. 215 to 220 consistently with a particular catty and normal draw and shoot intuitive.I find straight cuts a great way to increase life and the speed difference isn't that big a deal. Just experiment with the width.
A 22mm (7/8) straight cut with a 7 3/4 inch active length, with a 31+- inch draw should give about 198 fps 3/8 steel ammo. So adjust according to what factor is most important to you.
The draw weight of 12.6lbs is based on Thera gold of the same dimensions.
Yeah, My favorite TG is the 22mm (7/8) at 7 3/4 tie to tie and my draw has a range of 30 to 32. I do use other cuts for various cattys and reasons but my mainstay is the 22mm (7/8) You should experiment with going to 7 3/4 to 7.5 inch tie to tie.Hi Rayshot,
My favourite band is slightly weaker than what you tested. I often shoot 3/4" x 8" straight cut TBG with a 30" draw length. A 3/8" steel ball is tossed at 194 fps. I still have to order some Hygenic natural latex (Tex brand) to compare the 3/4" cut. With a 5/8" cut, I found the natural latex and the TBG shot about the same (both Hygenic products).
It would be interesting to see what happens between the TBG and Tex bands with various cuts and draw lengths. I'm guessing that the Hygenic Tex bands would excel a tiny bit with some cuts and draw lengths. As for band life, my TBG go around 1300 shots. I still have to order some Tex-Hygenic to test but my one set of 11/16" x 8" set are doing great.
Cheers,
Northerner
Cheers,
Northerner
M_J what is the band sizeSomebody tell me how a bandset with basically no draw weight can hit harder than a big, fat set of Trumark RRT tubes.
I got my Tex-Shooter Light bands today (along with a couple of "Field" sets) and tied them on my small boardcut. I went out to the garage to dent a can at 21ft. I didn't expect much in the way of power since the pull is rated at 8lb. I couldn't have been more wrong! These bands sent 3/8 steel right through both sides of a coke can and set the can spinning on the rope. Very accurate too! After halving the can (took almost no time! ) I tied it up with the bottom of the can facing me. It sent two right through that too! The only other bands/tubes I've done that with are my RRTs.
I can't say enough good things about this band set. The dimpled pouch is great too. Lighter pull and bigger power than my 107 rubber band set (NEVER going back!) and my looped 1842 tubes.
Really fantastic! Thanks Tex!
is that a tapered bandPretty sure it's the smallest one Tex has listed here.
