Decided to run tubes on my indoor practice scout and for some reason they keep snapping at the attachment point of my flip clip xs. Wondering if anyone else has had this problem and if so is there a solution?
This has happened before, and I'm once again in the dark. What are tube savers?Maybe you could run some tube savers over the actual tubes ?
Nothing more than a larger section of another tube ( like Theraband blue/black) that you slide over the ends of your active tubes at the fork attachment spot......just a protective sleeve or cuff for your main bands.This has happened before, and I'm once again in the dark. What are tube savers?Maybe you could run some tube savers over the actual tubes ?
Tha ks brother I will be trying this out. I have some extra tube sets for the Daisy f16 that will work I think as tube saversNothing more than a larger section of another tube ( like Theraband blue/black) that you slide over the ends of your active tubes at the fork attachment spot......just a protective sleeve or cuff for your main bands.This has happened before, and I'm once again in the dark. What are tube savers?Maybe you could run some tube savers over the actual tubes ?
Aha! I wasn't expecting anything this simple, logical or inexpensive. This sounds like a great idea for tube lifespan extension. Coincidentally, I just ordered the PP Taurus Trio three-frame set ten minutes ago. I'll definitely try this idea out on my new PP Taurus Tube Shooter as soon as it gets to me. Thanks for the idea.Nothing more than a larger section of another tube ( like Theraband blue/black) that you slide over the ends of your active tubes at the fork attachment spot......just a protective sleeve or cuff for your main bands.This has happened before, and I'm once again in the dark. What are tube savers?Maybe you could run some tube savers over the actual tubes ?
