Why do you require it to be around 300fps?
One reason only, just about all my shots are over 25 yards and most fall within the 28-35+ yard range... I need a flat trajectory, don't want softballs.Why do you require it to be around 300fps?
I have the Gold 1mm from Amazon that is 20mmx14mm that I re-cut the back end to get this 14mm tail size. That stuff shoots real well but it is $12.00 for 20 sets, a bit high, especially since their pouch is fudge and I change it.You can try using 1 mm latex so the band is not so wilde. 1cm from the pouch till 1.9 cm should be around good. Use a strong pouch though
Just bought some .8mm from them, hoping it works well in a 24mmx18mm config, 32.5" draw for 7/16' steel ;- ) We will see when it arrives. I have an assortment of latex coming ... this in .8 one, in 1mm and some from the USA that is .30thick.Aliexpress:Octopus Hunting Store
