Hello everybody !!
I have received 1 meter of 1745 tubing from Jeff(Thanks Jeff) and I connected them as the follow;
1. I cut 24 cm(both side 24-24) tube then looped it through the pouch so both ends of the tube are at the fork then I tied it.Unfortunetly the pouch cut the tubing within 50 shots lol
2..The tube was not fully cut through so I could change it and put the tube ends to the pouch and tied it there both end at the pouch.Problem was that this way my 24 cm tube was allready short so
the leftover tubing I wanna make them the right way. What do you recommend? I suppose #2 is good .
I am using the slingshot what you can see in my avatar.
Thanks
Thanks
