1 - 6 of 6 Posts
Hi, So I'm hunting wood pigeons at around 20m-30m with 25/20 0.75 single bands and 10mm steel. Of course I'm aiming for head but have had a few shots hit the body and appear to just bounce off. Question is am I under-powered with my bands and steel and maybe need to go double bands heavier steel?
Thanks
I’m assuming you have short draw? I think what Matt said is sound advise, I narrower cut and 9.5’s you should be able to get into the feathers. But pigeons can be very tough. My hunting setup right now is .65 elastic cut 5/8 to 3/8 (16mm to 10mm) with a 11”active length and 7/16 (11mm) steel, this maxes out at full butterfly and sends a sleeping pill. So far I’ve had nothing fly away from it after being hit.
You may even be overpowered... Though sounds kinda in the expected power range. You could go down to 22-18 maybe...
I'd probably go with smaller ammo as well - 9.5 or 8mm minimum. Or .36 lead ball
Matt said it for me, grab yourself some .36 (9mm'ish) lead.
I'm assuming you have short draw? I think what Matt said is sound advise, I narrower cut and 9.5's you should be able to get into the feathers. But pigeons can be very tough. My hunting setup right now is .65 elastic cut 5/8 to 3/8 (16mm to 10mm) with a 11"active length and 7/16 (11mm) steel, this maxes out at full butterfly and sends a sleeping pill. So far I've had nothing fly away from it after being hit.
That sounds like quite the setup mate, I'll have to give that a try. What type of elastic are you using?
1 - 6 of 6 Posts
